The Evolve 65 is a wireless headset with an integrated busylight and dual connectivity to two Bluetooth devices to enhance your productivity and freedom around the office. Features a wireless range of up to 30m away from your smartphone and/or PC.
30-meter (100 feet) wireless range
Get the freedom to leave your desk while on a call. Wireless Bluetooth technology 1.5 gives you up to 30-meter/100 feet of hands-free connectivity to PC, smartphone and tablet. -
Passive noise cancellation
Simply wear the headset to eliminate high-frequency noise, such as human voices - all thanks to the specially designed ear cushions. -
Busy light
The special "busy light" turns red to let people know when you're on the phone and keeps you from being interrupted. You can also turn it on manually when you don't want to be disturbed. -
Connect wirelessly via Bluetooth or directly using the USB cable. Dual connectivity enables you to connect to your PC and one other Bluetooth device at the same time, so you can take the call on your preferred phone device.
- Jabra Evolve 65 SE MS Stereo - headset - with charging stand
- Product Type
- Headset - Bluetooth - wireless - USB
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Stereo
- Sound Effects
- HD Voice
- Audio Specifications
- Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Max Input Power
- 10 mW
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume, on/off, answer/end, status indicator, reject call
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Bundled with
- Charging stand
- Designed For
- Jabra Evolve; LINK 380a MS
- Product Type
- Compatibility
- Mac, Windows
- 18.6 cm
- 6.05 cm
- 15.7 cm
- 111 g
- Body Material
- Aluminium
- Headband Material
- Foam, silicone
- Earpad Material
- Leatherette
- Recommended Use
- Max Operating Distance
- 30 m
- Bundled with
- Charging stand
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Hands-Free Profile (HFP), Audio Gateway Hands-Free Profile (AGHFP), Headset Profile (HSP)
- Sound Output Mode
- Stereo
- Sound Effects
- HD Voice
- 150 - 7000 Hz
- Max Input Power
- 10 mW
- Sensitivity
- 93.6 dB
- Diaphragm
- 28 mm
- Simultaneously Connectable Devices Qty
- 2
- Busy light, Jabra Direct, Jabra Xpress, SafeTone technology, digital signal processing, PeakStop technology, voice guidance
Microphone
- Boom
- Form Factor
- Headset microphone
- Uni-directional
- Sensitivity
- -17 dBFS/Pa
- 100 - 10000 Hz
- Noise Cancelling
- Audio Input Details
- Uni-directional - 100 - 10000 Hz
Remote Control
- Controls
- Included Accessories
- Neoprene pouch, Jabra Link 380a USB Adapter, charging stand
- Cable Details
- USB cable - detachable
- Plug and Play, FCC-ID, KCC, RCM, NCC, TELEC, SRRC, IC, G616
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 500 mAh
- Run Time (Up To)
- 12 hour(s)
- Standby Time
- 15 days
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
- Shipping Width
- 18.1 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 5.3 cm
- Shipping Weight
- 310 g
- Designed For
- Jabra Evolve , Jabra LINK 380a MS
