Your basket is empty
Jabra Evolve 40 MS Mono USB Headset
Quicklinx: 9TBWWS00 Mfr#: 6393-823-109
Recommended Use: Conference, Portable electronics
Connectivity: Wired
Earcover : Monaural
17 in stock
£57.45 ex VAT
£68.94 inc VAT
Express delivery Order within the next 3 hours for delivery tomorrow
The Jabra Evolve 40 MS mono is a professional headset designed mainly to improve conversations. Premium noise cancelling microphone eliminates background noise so your voice can be heard more clearly.
Microsoft Lync optimized with USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Jabra Evolve 40 MS mono - headset
Headset - wired
Recommended Use
Portable electronics, conference
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Headset
Recommended Use
Headphones
Supraaural
Wired
Available Microphone
Sound Output Mode
Mono
In-Cord Volume Control
Microphone
Boom
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Headset cable
Carrying pouch
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
Price Range Ex VAT: 50 - 100
