Jabra Evolve 40 MS, Mono, USB-C
Quicklinx: DLNKWS00 Mfr#: 6393-823-189
Select:
Hurry, only 3 left in stock!
£71.70 ex VAT
£86.04 inc VAT
Professional headset for greater productivity and amazing sound for calls and music.
  • Made for voice and music
    Truly made for both voice and music with world-class microphone and speakers so you are free to choose if you want to be in your own concentration tone or actively participate in voice-based collaboration.
  • Passive noise cancellation
    Passive noise cancellation gives you protection from high frequency noise such as human voices just by wearing the headset due to specially designed speaker cushions.
  • Easy Call Management
    Jabra headsets with in-line call controller give end users greater productivity and convenience, with large buttons and LCD indicators for quick access. Pick up or end calls, control volume or mute, or simply mule the line. Plus, all buttons are user-programmable.
  • Busy light
    The Jabra busy light helps you to tope with the challenges of an open office environment and let people clearly know that you are on the phone, the indicator turns red when you are on a call and keeps you from being interrupted.
  • Discrete boom arm
    Discrete boom arm can be seamlessly integrated into the headband when not on a call or when on the go - so you can easily turn your office headset into a personal headset.
Jabra Evolve 40 MS mono - headset
Headset - wired
Recommended Use
Phone, computer
Headphones Form Factor
On-ear - convertible
Wired
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance
32 Ohm
Max Input Power
5 mW
Microphone
Boom
Microphone Technology
Electret condenser
Controls
Mute, volume, answer/end
Headset - wired
142.5 g
Recommended Use
Phone, computer
Audio Output
Wired
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Frequency Response
150 - 7000 Hz
Max Input Power
5 mW
Sensitivity
93.6 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Busy light
Microphone
Boom
Headset microphone
Electret condenser
Frequency Response
10 - 10000 Hz
Audio Input Details
Uni-directional - 10 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (USB Type-C)
Carrying pouch
Cable Details
Control cable - 95 cm , Headset cable - 1.2 m
Shipping Width
19 cm
Shipping Depth
25.5 cm
Shipping Height
1 cm
