Jabra Evolve 40 Mono UC with 3.5mm Jack Only
Quicklinx: BTCBWS00 Mfr#: 14401-09
Recommended Use: Conference, Portable electronics
Connectivity: Wired
£30.71 ex VAT
£36.85 inc VAT
The Jabra Evolve 40 UC Mono is a professional headset designed to improve concentration and conversations. Premium noise-canceling technology gives you peace to work in the noisy, open office effectively creating a concentration zone around you, so you can stay focused on the job. The speakers are built for style and comfort with leatherette ear cushions, and are specifically designed to reduce office noise. The concentration zone is completed with a busy-light indicator that signals user availability to colleagues.
Let you and not the task decide where you work. The Jabra Evolve 40 comes with a 3.5mm jack stick incorporated into the control unit giving you the freedom to connect your corded headset to a PC, smartphone or tablet. The control unit also supports comfortable and easy access to most used functions, such as volume and mute. You are also able to answer calls and close calls directly at the control unit thereby increasing your overall flexibility, so you can better focus on the conversation. When not on a call or when you are on the go, the microphone boom arm can be seamlessly integrated into the headband - so you can easily turn your office headset into a personal headset.
The Jabra Evolve 40 UC Mono is optimized for Unified Communication, providing instant "Plug & Play" installation for your headset. The headset works perfectly with all leading vendors of Unified Communication systems, so you can focus on the conversation.
  • Stay focused
  • Optimized for Unified Communication
Jabra Evolve 40 Mono - headset
Headset - wired
Recommended Use
Portable electronics, conference
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - wired
Recommended Use
Headphones
On-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Connector Type
Headset (mini-phone 3.5 mm 4-pole)
Headset cable
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Jabra
Price Range Ex VAT: 0 - 50
