Jabra Evolve 40 Mono UC USB Headset
Quicklinx: 9TBYWS00 Mfr#: 6393-829-209
Recommended Use: Portable electronics, Computer
Connectivity: Wired
Earcover : Monaural
41 left in stock
£42.57 ex VAT
£51.08 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
The Jabra Evolve 40 MS Duo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
The Evolve 40 is a headset featuring amazing sound for calls and music, and an integrated busy-light to enhance your productivity by notifying colleagues that you are busy - therefore allowing you to avoid interruptions in the open office. Connect the headset using a USB or jack. Leather ear cushions allow for all-day comfort.
Microsoft Lync optimized with USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Intuitive Control Unit
Get easy access to the most used functions, such as volume and mute. You can also answer and end calls directly from the control unit.
Plug-and-play set up
Works out of the box with all leading systems. Installation is as easy as simply plugging it in.
Works will all mobile devices
The 3.5 mm jack lets you connect to a PC, smartphone, tablet or any other personal device.
Made for voice and music
World-class speakers are built for both voice and music. Switch easily between conversations and listening to your favourite tracks.
  • Made for voice and music
    Truly made for both voice and music with world-class microphone and speakers so you are free to choose if you want to be in your own concentration tone or actively participate in voice-based collaboration.
  • Passive noise cancellation
    Passive noise cancellation gives you protection from high frequency noise such as human voices just by wearing the headset due to specially designed speaker cushions.
  • Easy Call Management
    Jabra headsets with in-line call controller give end users greater productivity and convenience, with large buttons and LCD indicators for quick access. Pick up or end calls, control volume or mute, or simply mule the line. Plus, all buttons are user-programmable.
  • Busy light
    The Jabra busy light helps you to tope with the challenges of an open office environment and let people clearly know that you are on the phone, the indicator turns red when you are on a call and keeps you from being interrupted.
  • Discrete boom arm
    Discrete boom arm can be seamlessly integrated into the headband when not on a call or when on the go - so you can easily turn your office headset into a personal headset.
Jabra Evolve 40 UC mono - headset
Headset - wired - 3.5 mm jack
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Sound Effects
PureSound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 93.6 dB
Impedance
32 Ohm
Max Input Power
10 mW
Microphone
Boom
Controls
Mute, volume, answer/end
Dimensions & Weight Details
Headset: 5.86 cm x 15.54 cm x 18.1 cm / 80 g , Control unit: 55 g
5.86 cm
15.54 cm
18.1 cm
80 g
Earpad Material
Leatherette
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Sound Effects
PureSound
Frequency Response
20 - 20000 Hz
Max Input Power
10 mW
Sensitivity
93.6 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Busy light
Microphone
Boom
Headset microphone
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.2 m
Carrying pouch
Cable Details
Headset cable - 1.2 m , USB control cable - detachable - 95 cm
Plug and Play, UL, FCC, KCC, RCM
Shipping Width
25.5 cm
Shipping Depth
19 cm
Shipping Height
10 cm
Shipping Weight
142.5 g
9TBY Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £48.89
9TBY Jabra Evolve 40 UC Mono - Replacement Headset Only In Stock £42.51
Recommended Use: Computer
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
Stock Status: While stocks last
Stock Status: Clearance
