The Jabra EVOLVE 40 UC duo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Superior comfort
The Jabra Evolve 40 Stereo headset is designed with high-quality leatherette earpads that ensure comfort for prolonged use, making it perfect for professionals who spend a lot of time on calls or listening to music. -
Exceptional audio clarity
Featuring a boom-mounted microphone and stereo sound output, the Jabra Evolve 40 Stereo delivers clear, high-quality audio whether you're on a call or enjoying multimedia on your portable electronics. -
Effortless connectivity
With its wired connectivity technology and a mini-phone stereo 3.5 mm 4-pole connector, this headset offers a reliable connection to a wide range of devices, ensuring seamless audio experiences without the hassle of battery management.
- Jabra Evolve 40 Stereo - headset
- Product Type
- Headset - wired
- Recommended Use
- Portable electronics, conference
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Product Type
- Headset
- Earpad Material
- Leatherette
- Recommended Use
Headphones
- Supraaural
- Wired
- Available Microphone
- Sound Output Mode
- Stereo
Microphone
- Boom
- Connector Type
- Headset ( mini-phone stereo 3.5 mm 4-pole )
- Cables Included
- Headset cable
