The Jabra Evolve 40 MS Duo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
The Evolve 40 is a headset featuring amazing sound for calls and music, and an integrated busy-light to enhance your productivity by notifying colleagues that you are busy - therefore allowing you to avoid interruptions in the open office. Connect the headset using a USB or jack. Leather ear cushions allow for all-day comfort.
Microsoft Lync optimized with USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Intuitive Control Unit
Get easy access to the most used functions, such as volume and mute. You can also answer and end calls directly from the control unit.
Plug-and-play set up
Works out of the box with all leading systems. Installation is as easy as simply plugging it in.
Works will all mobile devices
The 3.5 mm jack lets you connect to a PC, smartphone, tablet or any other personal device.
Made for voice and music
World-class speakers are built for both voice and music. Switch easily between conversations and listening to your favourite tracks.
Truly made for both voice and music with world-class microphone and speakers so you are free to choose if you want to be in your own concentration tone or actively participate in voice-based collaboration. -
Passive noise cancellation
Passive noise cancellation gives you protection from high frequency noise such as human voices just by wearing the headset due to specially designed speaker cushions. -
Easy Call Management
Jabra headsets with in-line call controller give end users greater productivity and convenience, with large buttons and LCD indicators for quick access. Pick up or end calls, control volume or mute, or simply mule the line. Plus, all buttons are user-programmable. -
Busy light
The Jabra busy light helps you to tope with the challenges of an open office environment and let people clearly know that you are on the phone, the indicator turns red when you are on a call and keeps you from being interrupted. -
Discrete boom arm
Discrete boom arm can be seamlessly integrated into the headband when not on a call or when on the go - so you can easily turn your office headset into a personal headset.
 - Jabra Evolve 40 UC stereo - headset - 3.5 mm jack
- Product Type
 - Headset - wired - 3.5 mm jack
- Recommended Use
 - Portable electronics, computer - communication
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - PureSound
- Audio Specifications
 - Frequency Response 20 - 20000 Hz - Sensitivity 93.6 dB
- Impedance
 - 32 Ohm
- Max Input Power
 - 10 mW
- Microphone
 - Boom
- Controls
 - Mute, volume, answer/end
 - 2-year warranty
- Product Type
- Dimensions & Weight Details
 - Headset: 5.86 cm x 15.55 cm x 18.09 cm / 113 g , Control unit: 55 g
 - 5.86 cm
 - 15.55 cm
 - 18.09 cm
 - 113 g
- Earpad Material
 - Leatherette
- Recommended Use
Audio Output
 - On-ear
 - Wired
- Sound Output Mode
 - Stereo
- Sound Effects
 - PureSound
 - 20 - 20000 Hz
- Max Input Power
 - 10 mW
- Sensitivity
 - 93.6 dB
- Impedance
 - 32 Ohm
- Diaphragm
 - 28 mm
- In-Cord Volume Control
- Adjustable Headband
 - Busy light
Microphone
 - Boom
- Form Factor
 - Headset microphone
 - 100 - 10000 Hz
- Audio Input Details
 - Uni-directional - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
 - Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
 - 1.2 m
- Included Accessories
 - Carrying pouch
- Cable Details
 - Headset cable - 1.2 m , USB control cable - detachable - 95 cm
 - Plug and Play, UL, FCC, KCC, RCM
 - Limited warranty - 2 years
- Shipping Width
 - 25.5 cm
- Shipping Depth
 - 19 cm
- Shipping Height
 - 10 cm
- Shipping Weight
 - 171.1 g
                        Jabra Evolve LINK USB UC Controller Only | In Stock | £40.53 |
                        Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units | In Stock | £34.40 |
                        Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 | In Stock | £47.91 |
                        Jabra USB-A to USB-C Adapter | In Stock | £12.40 |
                        Jabra Foam Ear Cushion for Jabra EVOLVE 20 65 10 units pack | In Stock | £11.04 |
