Jabra Evolve 30 UC Mono USB Headset
Quicklinx: 9TBTWS00 Mfr#: 5393-829-209
The Jabra Evolve 30 UC mono is a professional headset designed mainly to improve conversations. Premium noise cancelling microphone eliminates background noise so your voice can be heard more clearly.
Optimized for Unified Communication with USB adapter that enables easy integration with PC. Built for style and comfort with leatherette ear cushions. Soft pouch included.
  • NOISE-CANCELLING MIC
    State-of-the-art, noise-cancelling microphone eliminates background noise. Your conversation partner won't struggle to hear what you're saying.
  • PLUG-AND-PLAY SETUP
    Works out of the box with all leading systems. Installation is as easy as simply plugging it in.
  • Intuitive control unit for ease of use
    Provides easy access to common functions, such as answering or ending calls, controlling volume, and muting conversations.
  • Plug-and-play setup for quick user adoption
    Works out of the box with any platform. Installation is as easy as simply plugging it in via USB.
  • Mass deployment made easy and affordable
    Low-end models offer an easy and affordable way to improve your team's concentration.
  • Made for voice and music
    Truly made for both voice and music with world-class microphone and speakers, so you are free to choose whether you want to be in your own concentration zone or actively participate in voice-based collaboration.
  • Passive noise cancellation
    Due to specially designed speaker cushions, passive noise cancellation gives you protection from high-frequency noise such as human voices just by wearing the headset.
Jabra Evolve 30 UC mono - headset
Headset - wired
Recommended Use
Portable electronics, conference
Headphones Form Factor
Full size
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - wired
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Mono
In-Cord Volume Control
Microphone
Boom
Remote Control
Headset remote control
Controls
Connector Type
Headset (4 PIN USB Type A)
Carrying pouch
Cable Details
Headset cable
