Product
Jabra Evolve 30 MS Duo USB Headset
Quicklinx: 9TBSWS00 Mfr#: 5399-823-109
The Jabra Evolve 30 MS stereo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
Microsoft Lync optimized with USB adapter that enables easy integration with PC. Built for style and comfort with leatherette ear cushions. Soft pouch included.
  • Stay focused, by eliminating distractions in noisy open office environments
    The Jabra Evolve series helps you create your own concentration zone with premium active and passive noise cancellation technology - so that you, and not noisy disturbances, are in control. Get further protection from interruptions with the busy light that signals whether or not you are available to colleagues.
  • Made for both music and voice
    With a world-class set of microphone and speakers that are truly made for both voice communication and music listening, you are free to choose if you want to be in your own concentration zone or actively participate in voice-based collaboration.
  • Let you, not the task, decide where you work
    Use your headset where you want. Connect easily to your PC via the USB-based control unit or to your smartphone and tablet via the 3.5 mm jack. Additionally you can easily change your office headset to a very stylish personal head- set when you're on the go by seamlessly integrating the microphone boom arm into the headband.
Jabra Evolve 30 MS stereo - headset
Headset - wired
Recommended Use
Portable electronics, conference
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Microphone
Boom
Controls
Mute, volume, answer/end
Headset
Recommended Use
Headphones
Circumaural
Wired
Sound Output Mode
Stereo
In-Cord Volume Control
Microphone
Boom
Remote Control
Headset remote control
Controls
Connector Type
Headset (4 PIN USB Type A)
Headset cable
Carrying pouch
