Jabra Evolve 30 Mono UC USB Headset
Quicklinx: CB12WS00 Mfr#: 5393-829-309
Recommended Use: Portable electronics, Computer
Connectivity: Wired
Earcover : Monaural
33 left in stock
£32.56 ex VAT
£39.07 inc VAT
Express delivery Order within the next 18 hours for delivery on Monday
The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
  • NOISE-CANCELLING MIC
    State-of-the-art, noise-cancelling microphone eliminates background noise. Your conversation partner won't struggle to hear what you're saying.
  • PLUG-AND-PLAY SETUP
    Works out of the box with all leading systems. Installation is as easy as simply plugging it in.
  • Intuitive control unit for ease of use
    Provides easy access to common functions, such as answering or ending calls, controlling volume, and muting conversations.
  • Plug-and-play setup for quick user adoption
    Works out of the box with any platform. Installation is as easy as simply plugging it in via USB.
  • Mass deployment made easy and affordable
    Low-end models offer an easy and affordable way to improve your team's concentration.
  • Made for voice and music
    World-class speakers are built for both voice and music. Switch easily between conversations and listening to your favourite tracks.
  • Passive noise-cancellation
    Simply wear the headset to eliminate high-frequency noise, such as human voices - all thanks to the specially designed ear cushions. We call this "passive noise-cancellation."
  • Easy call management
  • Stay focused, by eliminating distractions in noisy open office environments
    The Jabra Evolve series helps you create your own concentration zone with premium active and passive noise cancellation technology - so that you, and not noisy disturbances, are in control. Get further protection from interruptions with the busy light that signals whether or not you are available to colleagues.
  • Made for both music and voice
    With a world-class set of microphone and speakers that are truly made for both voice communication and music listening, you are free to choose if you want to be in your own concentration zone or actively participate in voice-based collaboration.
  • Let you, not the task, decide where you work
    Use your headset where you want. Connect easily to your PC via the USB-based control unit or to your smartphone and tablet via the 3.5 mm jack. Additionally you can easily change your office headset to a very stylish personal head- set when you're on the go by seamlessly integrating the microphone boom arm into the headband.
Jabra Evolve 30 II UC Mono - headset
Headset - wired - 3.5 mm jack
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance
32 Ohm
Max Input Power
10 mW
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Earpad Material
Leatherette
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Sound Effects
Crystal Clear
Frequency Response
150 - 7000 Hz
Max Input Power
10 mW
Sensitivity
93.6 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
PeakStop technology
Microphone
Boom
Headset microphone
Electret condenser
Sensitivity
-44 dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Audio Input Details
- 100 - 10000 Hz
Remote Control
Controls
Cable
Cable Length
1.2 m
Carrying pouch
Cable Details
Headset cable - 1.2 m , USB control cable - detachable - 95 cm
Plug and Play, UL, FCC, KCC, RCM
Shipping Width
18 cm
Shipping Depth
23 cm
Shipping Height
3.5 cm
Shipping Weight
142.5 g
CB12 Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £48.89
Recommended Use: Computer
Connectivity: Wired
Earcover : Monaural
Brand: Jabra
Stock Status: While stocks last
Stock Status: Clearance
