The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
Noise-canceling mic
The great noise-canceling microphone eliminates background noise. Your conversation partner won't struggle to hear what you're saying. -
Plug-and-Play setup
It works out of the box with most systems. Installation is as easy as simply plugging it in. -
Intuitive control unit for ease of use
Provides easy access to common functions, such as answering or ending calls, controlling volume, and muting conversations. -
Made for voice and music
Amazing speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. -
Passive noise cancellation
Simply wear the headset to eliminate high-frequency noise, such as human voices - all thanks to the specially designed ear cushions. -
Easy call management
- Jabra Evolve 30 II UC stereo - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- Audio Specifications
- Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
- Impedance
- 32 Ohm
- Max Input Power
- 10 mW
- Microphone
- Boom
- Microphone Technology
- Electret condenser
- Microphone Active Noise Cancelling
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- Earpad Material
- Leatherette
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Crystal Clear
- 150 - 7000 Hz
- Max Input Power
- 10 mW
- Sensitivity
- 93.6 dB
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- In-Cord Volume Control
- Adjustable Headband
- PeakStop technology
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -44 dB
- 100 - 10000 Hz
- Active Noise Cancelling
- Audio Input Details
- - 100 - 10000 Hz
Remote Control
- Controls
Cable
- Cable Length
- 1.2 m
- Included Accessories
- Carrying pouch
- Cable Details
- Headset cable - 1.2 m , USB control cable - detachable - 95 cm
- Plug and Play, UL, FCC, KCC, RCM
- Limited warranty - 2 years
- Shipping Width
- 18 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 3.5 cm
- Shipping Weight
- 171.1 g
Jabra USB-A to USB-C Adapter | In Stock | £7.75 |
