Jabra Evolve 20 SE  Duo MS USB Headset
Quicklinx: D5TYWS00 Mfr#: 4999-823-309
Recommended Use: Computer
Connectivity: Wired
More than 50 in stock
£38.04 ex VAT
£45.64 inc VAT
Professional headset with easy call management and great sound for calls and music!
More than headsets, a workplace evolution
With great sound for calls and music, the Evolve 20 and 20 Special Edition are entry-level professional headsets with easy call management through a control unit that makes, takes and mutes calls. Simple connectivity makes it easy to get started with your PC.
Clearer conversation for greater efficiency
Entry-level professional headset with easy call management and great sound for calls and music.
Manage calls easily
Get easy access to the most used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
Flexible Plug and Play connectivity
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop.
All day comfort (Evolve 20SE)
Built for style and comfort with soft leatherette ear cushions. Adjustable headband lets you find the perfect fit.
  • Clearer conversation for greater efficiency
  • Manage calls easily
    Get easy access to often used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
  • Flexible Plug and Play connectivity
  • All-day comfort
Jabra Evolve 20SE MS stereo - Special Edition - headset
Headset - wired - USB
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Audio Specifications
Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance
32 Ohm
Max Input Power
5 mW
Microphone
Boom
Microphone Technology
Electret condenser
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business
Headset - USB
Earpad Material
Leatherette
Recommended Use
Headphones
Supraaural
Wired
Sound Output Mode
Stereo
Sound Effects
Crystal Clear
Frequency Response
150 - 7000 Hz
Max Input Power
5 mW
Sensitivity
93.6 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
PeakStop technology
Microphone
Boom
Headset microphone
Electret condenser
Sensitivity
-44 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
1.2 m
Headset cable - 1.2 m , USB control cable - 95 cm
Carrying pouch
Plug and Play, UL, FCC, KCC, RCM
Shipping Width
18 cm
Shipping Depth
23 cm
Shipping Height
3.5 cm
D5TY Jabra Earcushion leather for Jabra Evolve 20, 30, 40, 65 - 10 units In Stock £25.36
D5TY Jabra Headset Pouch For Jabra Evolve 20, 30, 40, 65, - Pack 10 In Stock £38.13
Connectivity: Wired
Brand: Jabra
Price Range Ex VAT: 0 - 50
