Work away from the desk and still maintain a wireless connection that won't let you, or your customers, down.
Industry-leading wireless performance
Provides superior wireless connectivity to a range of 150 metres, enabling 3x more users in the same office space – with no loss in connection quality. Work away from the desk and still maintain a connection that won't let you, or your customers, down. -
Crystal-clear calls
Advanced noise-cancelling microphone and enhanced speakers deliver crystal-clear calls even in noisy offices. -
Premium usability and build
Easily answer and end calls, mute and adjust volume using the intuitive controls on the headset. -
Industry-leading wireless performance. Better customer connections.
 - Jabra Engage 65 SE Convertible - headset
- Product Type
 - Headset - DECT - wireless
- Recommended Use
 - Computer, conference - voice, communication
- Localisation
 - Australia, Hong Kong, New Zealand, Singapore, United Kingdom
- Headphones Form Factor
 - On-ear - convertible - monaural
- Connectivity Technology
 - Wireless
- Wireless Technology
 - DECT
- Sound Output Mode
 - Mono
- Audio Specifications
 - Frequency Response 40 - 16000 Hz
- Microphone
 - Boom
- Microphone Technology
 - Electret condenser
- Microphone Operation Mode
 - Uni-directional
- Microphone Noise Cancelling
- Controls
 - Mute, answer/end, reject call
- Environmental Standards
 - TCO Certified Headsets 9
- Software Certification
 - Zoom Certified, Google Meet Certified, Amazon Chime Certified, Works With Chromebook Certified, UC certified
 - 2-year warranty
- Product Type
 - 21 g
- Recommended Use
 - In-call LED indicator, mute LED indicator, over the air updates, Battery status indicator, sleep mode
- Max Operating Distance
 - 100 m
- Localisation
Audio Output
 - Wireless
 - DECT
- Sound Output Mode
 - Mono
 - 40 - 16000 Hz
 - Busy light, PeakStop technology, Jabra Direct, Jabra Xpress, SafeToneTM 2.0, Jabra SDK
- Audio Output Details
 - Multimedia - 40 - 16000 , Communication - 150 - 6800
Microphone
 - Boom
- Form Factor
 - Headset microphone
 - Uni-directional
 - 100 - 10000 Hz
- Noise Cancelling
- Noise Cancelling Technology
 - Advanced Noise Control
Remote Control
- Controls
- Included Accessories
 - Headband, power adapter, earhook, base unit, 3 pairs of EarGels, USB-C to USB-A cable, cable adapter
- Cable Details
 - USB-C to USB-A cable - detachable , Phone cable - detachable
 - G616
Sustainability Information
- TCO Certified
- Battery
 - Headset battery rechargeable - Lithium Ion
- Capacity
 - 170 mAh
- Run Time (Up To)
 - 9 hour(s)
- Run Time Details
 - Continuous talk (busy light off): up to 9 hour(s)
- Recharge Time
 - 1.5 hour(s)
 - Limited warranty - 2 years
- Shipping Width
 - 14.5 cm
- Shipping Depth
 - 19 cm
- Shipping Height
 - 9.5 cm
 - -10 °C
 - 55 °C
- Min Storage Temperature
 - -5 °C
- Max Storage Temperature
 - 45 °C
