Jabra Engage 55 is ideal for hybrid workers who spend most of their day on calls or virtual meetings. With a lightweight, comfortable design for all-day wear, outstanding wireless range and robust DECT Level C security, it's the perfect headset for hybrid working.
                Everybody's talkingHave better conversations, both at home and in the office, with Engage 55. This intuitive headset is designed for those who spend most of their day in calls or virtual meetings, giving you an extensive wireless range and the highest levels of security, for maximum peace of mind. Whether you're working from home or a busy office, Engage 55 will keep you sounding professional for every single conversation, no matter what's happening around you.
                Free range (conversations, not chickens)Whether you're working from home or in the office, it's nice to have the freedom to move around. Engage 55's compact USB DECT adapter delivers a wireless range of up to 150m from your computer and also makes it easy for you to move about with your laptop while you're on a call. Head to the kitchen for a coffee or walk a few laps of the office, without worrying about whether your connection will hold.
                PowerDECT wireless is specifically designed for wireless communications, making it an ideal choice for call-intensive workers who need additional mobility. In fact, the DECT wireless range of Engage 55 is up to 15 times the average range of a Class 2 Bluetooth device. And if you're working in a busy office, DECT wireless is built to withstand the density of large numbers of people working in the same place, so you'll get a clear, robust and secure connection for your conversations.
                Like Fort KnoxHowever you're working these days, if your conversations often include sensitive details, it's important to know that the data is protected. The ultra-secure wireless adapter for Engage 55 is DECT Security certified. But because your data security is so important to us, we go beyond the DECT Security Step C level with additional FIPS military-grade 256-bit encryption algorithms, to prevent eavesdropping and keep conversations secure.
                This sounds seriousWhen you're in back-to-back calls or virtual meetings, every word matters. Engage 55 features an impressive noise-cancelling microphone that helps block out background noise to keep you sounding like a pro, whichever office you're working from. The speakers are optimised for speech clarity, while wideband audio delivers crisp, crystal clear, natural-sounding calls. So you can wave goodbye to crackly, robotic-sounding voices and say hello to more engaging conversations.
                Coffee to call in secondsFrom the moment you first unbox your new Engage 55, you're ready to start having seamless, easy calls. Just plug the pre-paired USB DECT adapter into your computer and you're good to go. With this easy-to-use, single-connectivity headset, you're never more than a few seconds from your first call on your computer.
                As flexible as your scheduleWhether you're hot desking or switching it up between home and the office, our durable Link 400 adapter is built to withstand the demands of your day. It's designed to bend, reducing the risk of damage even if you leave it plugged into your laptop. Perfect for companies with clear desk policies or workers who like a change of scenery.
                Long-day-proofAn uncomfortable headset can really distract your focus from the conversation. That's why we've made sure Engage 55 is lightweight, with a low clamping force, to avoid pressure and heat build-up. So even when you're in back-to-back calls all day, you can rely on your headset to help you keep your cool.
                It's oh so quietNobody wants to be that guy shouting on all their calls. That's why Engage 55 has adjustable Sidetone built in. By playing a little of your voice into your speakers as you talk, Sidetone helps you to regulate your speech volume, reassuring you that your microphone is working and combating conversation fatigue.
                It's what we doWe've engineered Engage 55 with SafeToneTM 2.0, for superior built-in hearing protection. What's SafeTone 2.0 made up of? PeakStop prevents sudden loud audio spikes IntelliTone 2.0 limits overall audio exposure Speech Level Normalization and Intelligent Acoustic Shock Prevention maintain comfortable audio levels throughout the day This advanced technology protects your hearing well-being, while also helping to prevent the virtual conversation fatigue that can result from poor audio.
                Works with everythingWhichever communication platform you use, Engage 55 is ready. It works with all leading Unified Communications (UC) and contact centre platforms for a seamless experience. The UC variant is certified for Google Meet, Zoom and more, while the Microsoft variant is certified for Microsoft Teams.
                Always a step aheadThere's plenty to love about Engage 55 from the word 'go' and our firmware updates will keep it running in peak condition. Our Jabra Xpress and Jabra Direct software will keep your headset up-to-date and running as smoothly as the day you unboxed it, for many years to come.
                Protect your focusThe built-in busylight on Engage 55 helps you wave goodbye to interruptions. Automatically glowing red when you're on a call, it shows anyone nearby that you're in 'do not disturb' mode.
                Ready when you areWith up to 13 hours 1 of battery life, you're unlikely to run out of juice mid-flow. But in the unlikely event that you do hear the dreaded 'battery low', easy in-call charging 2 means you'll never drop a call. Simply plug the cable in and carry on the conversation. 1 Battery life for stereo and mono models is up to 13 hours. Battery life for convertible model is up to 9 hours. 2 Stereo and mono variants. Not recommended for convertible model.
                Made for you (yes, you)Because everyone's preferences are different, Engage 55 is available in three different wearing styles to suit any working preference, with a stereo, mono and a convertible model that comes with an earhook, neckband and headband, so you can pick the style that suits you best.
- Jabra Engage 55 Stereo - headset
- Product Type
- Headset - DECT - wireless
- Compatibility
- Mac, Windows
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Controls
- Mute, volume, answer/end, reject call
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Product Type
- Compatibility
- Mac, Windows
- 83 g
- Earpad Material
- Leatherette
- Recommended Use
- Computer
- Protection
- FIPS 140-2
- Max Operating Distance
- 150 m
Audio Output
- On-ear
- Wireless
- DECT
- Sound Output Mode
- Stereo
- Busy light, PeakStop technology, Jabra Direct, Jabra Xpress, SafeToneTM 2.0, IntelliTone 2.0, Speech Level Normalisation, Intelligent Acoustic Shock
Microphone
- Boom
- Form Factor
- Headset microphone
- Uni-directional
Remote Control
- Controls
- Included Accessories
- Charging stand, Jabra Link 400 USB-C Adapter
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 13 hour(s)
- Limited warranty - 2 years
