Your basket is empty
Jabra EHS Solution
Jabra EHS Solution
Quicklinx: 6P65WS00 Mfr#: 14201-17
Recommended Use: Accessory
Connectivity: Wired
Earcover : [N/A]
More than 50 due in 1-2 days
£24.63 ex VAT
£29.55 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Polycom SoundPoint IP phones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
Jabra EHS Adapter - headset adapter - 92.5 cm
Cable
Headset adapter
Length
92.5 cm
Jabra GN9120 Duo, GN9120 Midi, GN9350; Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Cable Type
Headset adapter
Length
92.5 cm
C-Tick, NOM, IC, FCC
Jabra GN9120 Duo, GN9120 Midi, GN9350 , Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Connectivity: Wired
Earcover : [N/A]
Brand: Jabra
Price Range Ex VAT: 0 - 50
