Jabra EHS Cable For Polycom IP Phones
Quicklinx: 6P65WS00 Mfr#: 14201-17
Recommended Use: Accessory
Connectivity: Wired
Earcover : [N/A]
22 in stock
£23.93 ex VAT
£28.71 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Polycom SoundPoint IP phones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra Link 14201-17 - headset adapter - 92.5 cm
Cable
Headset adapter
Length
92.5 cm
Answer/end button, mute switch, volume buttons, Electronic Hook Switch Control (EHS)
1-year warranty
Jabra GN9120 Duo, GN9120 Midi, GN9350; Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Cable Type
Headset adapter
Length
92.5 cm
Plug and Play, C-Tick, NOM, IC, FCC
Limited warranty - 1 year
Jabra GN9120 Duo, GN9120 Midi, GN9350 , Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Connectivity: Wired
Earcover : [N/A]
Brand: Jabra
Price Range Ex VAT: 0 - 50
