Jabra LINK EHS Adapter for Cisco IP Phones for 8900 and 9900 Series
Quicklinx: 7Z8PWS00 Mfr#: 14201-30
Type: Cable
Hurry, only 3 left in stock!
£19.07 ex VAT
£22.88 inc VAT
Express delivery Order within the next 14 hours for delivery on Monday
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Cisco deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra Link 14201-30 - headset adapter - 90 cm
Cable
Headset adapter
Length
90 cm
Connectors
USB - male
Connectors (Second End)
RJ-11 - male , RJ-45 - male
Answer/end button, mute switch, volume buttons, Electronic Hook Switch Control (EHS)
1-year warranty
Cisco Unified IP Phone 8941 Slimline, 8941 Standard, 8945 Slimline, 8945 Standard, 8961 Slimline, 8961 Standard, 9951 Slimline, 9951 Standard, 9971 Slimline, 9971 Standard
Cable Type
Headset adapter
Length
90 cm
Connectors
4 pin USB Type A - male
Plug and Play, C-Tick, FCC
Limited warranty - 1 year
Type: Cable
Brand: Jabra
Stock Status: While stocks last
Stock Status: Clearance
