Product
Brand
Jabra BT2046 Bluetooth Headset Without Charger
Quicklinx: 8GR0WS00 Mfr#: 100-92046000-40
Making wireless calling easy
The new Jabra BT2046 is the perfect way to get the most out of your busy schedule and of your calls on the go. This intuitively designed Bluetooth® headset is made to be paired easily with your mobile phone and is practical to operate. With its new, improved look, the Jabra BT2046 gives you enhanced comfort by allowing you to choose whether to use it with or without an earhook. With its attractive and user-friendly design, the Jabra BT2046 makes wireless calling easy.
Safe driving
Matching safety while driving and calls is of outmost importance at Jabra. Jabra BT2046 provides true hands-free convenience and exceptional ease-of-use, so that you can drive safely, keeping in touch and making your calls without wires and with both hands on the wheel.
Make the most of your calls
Whether at home or on the go, get the most out of your calls and your time with the Jabra BT2046. Optimised sound quality on all your calls, great value for money and a practical and intuitive headset is ensured. The Jabra BT2046 delivers solid performance and an appealing design at a great price - all in one package.
  • Easy to use, wear and enjoy
  • Attractive design
  • Clear sound
  • Multiuse™ - connects to 2 Bluetooth® devices simultaneously
  • Up to 8 hours' talk time and up to 10 days' standby time
Wireless Technology:
Bluetooth. Supports Bluetooth™ for wireless connectivity
Bluetooth version:
2.1
AVRCP:
No. This device does not support AVRCP, meaning you cannot control your music directly from the device
Auto Pairing:
Yes. With Auto Pairing, a device pairs automatically with Bluetooth® devices supporting this feature
NFC Near Field Communications
No
Music Streaming:
No. This device cannot stream music.
Speakers
Frequency Response
Narrowband
Digital Signal Processing
No
Microphone
Microphone Type:
Omni Directional/Noise Filter
Mute function:
No
Battery & Power
Talk Time:
Up to 8 hours
Standby Time:
Up to 240hour(s)
USB Charging:
Design
Wearing Style:
In the ear
Weight (oz): 0.34oz
0.34oz
Length:
53mm
Width:
16mm
Depth:
25mm
Control
Movement Sensors:
No
