Jabra BIZ 2400 II Duo NC Headset Top only
Quicklinx: B947WS00 Mfr#: 2409-820-204
Recommended Use: Conference, Office
Connectivity: Wired
Earcover : Binaural
More than 50 in stock
£129.74 ex VAT
£155.68 inc VAT
The BIZ 2400 II offers outstanding sound at both ends of the call for a superior customer experience, a corded professional headset that delivers outstanding sound on both ends of the call. Up to 40% lighter than competing headsets and with a low pressure, super-soft leatherette headband, the Biz 2400 II allows the agent to focus on their customer conversation in unrivalled comfort.
Better conversation
The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The ultra-noise-cancelling microphone provides the highest degree of background noise elimination in any of our headsets.
  • Better conversation
    The most important function of a contact centre headset is eliminating background noise from the busy environment and letting the customer hear your voice clearly. The Biz 2400 II has a superior noise-cancelling microphone that helps eliminate background noise to give a better customer experience.
  • Better sound
    If you're in a busy environment, you need great sound to hear the voice of your customer. Additionally, when you're concentrating on work, you want that hi-fi sound for music. The Jabra Biz 2400 II is great at both. HD Voice technology makes sure you clearly understand the other party The speakers reduce ambient noise, so you can focus on the call A specially designed "air shock" noise-cancelling mic filters out sharp breathing sounds and popping noises often heard in conversations.
  • Better design
    The Jabra Biz 2400 II is built to last in a high-performing contact centre, meaning fewer headset replacements and less downtime for you and your team and lower total cost of ownership. Reinforced cord is built to withstand the contact centre environment and is protected against office chair wheels, sharp objects and daily use The boom-arm can be rotated 360 degrees with zero risk of breaking. We call this FreeSpin .
  • Better comfort
    The Jabra Biz 2400 II has an extremely lightweight and unobtrusive design. This means less agent fatigue and more productive calls. 40% lighter than competing high-end headsets The adjustable headband and microphone boom arm let you find the perfect fit The control unit lets you change volume, mute your calls and more PeakStop technology removes sudden loud sounds or tones before they reach your ears: Any sound above 118 dB is filtered out. Super-soft leatherette head and ear cushioning.
Jabra BIZ 2400 II QD Duo NC - headset
Headset - wired
Headphones Form Factor
On-ear
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Microphone
Boom
Headset
Headphones
Supraaural
Dynamic
Wired
Sound Output Mode
Stereo
Microphone
Boom
Connector Type
Headset
B947 Jabra LINK 850 Amplifier In Stock £69.80
B947 Jabra LINK 230 QD - USB Adapter In Stock £23.51
B947 Jabra Link 260 USB-amplifier QD to USB In Stock £50.17
B947 Jabra BIZ 2400 Leatherette ear cushions, 10 unit PACK In Stock £19.59
B947 Jabra Smart Cord GN1218, QD To RJ9 For Jabra QD Headsets In Stock £18.88
Recommended Use: Office
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 100 - 150
