Product
Jabra BIZ 2300 Duo + GN1200 Straight Smart Cord
Quicklinx: B8H9WS00 Mfr#: 2309-820-104+88001-99
Recommended Use: Phone, Phone
Connectivity: Wired
Earcover : Binaural
More than 50 in stock
£99.79 ex VAT
£119.74 inc VAT
Express delivery Delivered on Tuesday
Your contact centre agents are your brand ambassadors, so give them the tool to sound as clear as your brand. In Jabra's Biz 2300, world-class sound meets world-class durability in an exceptionally comfortable and stylish corded headset – keeping both your agents and your customers happy.
Jabra Biz 2300 QD Duo is a duo headset with QD (Quick Disconnect) plug that provides instant connectivity to a wide range of deskphone systems.
Includes GN1200 Smart Cord in the product box
  • A headset that's built to last
    The Jabra Biz 2300 is built to survive in a high-performing contact centre, meaning fewer headset replacements and less downtime for you and your team and lower total cost of ownership. Reinforced cord is built to withstand the contact centre environment and is protected against office chair wheels, sharp objects and daily use The boom-arm can be rotated 360 degrees with zero risk of breaking. We call this FreeSpin .
  • All-day comfort for agents
    Extremely lightweight and unobtrusive design means lowered agent fatigue and more productive calls. Weighs just 49 grams in the mono version, and just 68 grams in duo The adjustable headband and microphone boom-arm let you find the perfect fit The control unit lets you change volume, mute your calls and more PeakStop technology removes sudden loud sounds or tones before they reach your ears: Any sound above 118 db is filtered out.
  • World-class sound
    Lifelike conversations and higher customer satisfaction require both great, ambient-noise reducing sound in the agent's ears, and a noise-cancelling microphone that also avoids air shocks. The Jabra Biz 2300 has both. HD Voice technology makes sure you clearly understand the other party The speakers reduce ambient noise, so you can focus on the call Specially designed "air shock" noise-cancelling mic filters out sharp breathing sounds and popping noises often heard in conversations.
  • Air shock microphone
    When the microphone is close to the mouth of the user, there is a risk of respiratory noise. To reduce this, the microphone is designed aerodynamically and with many small holes instead of one larger hole. In addition, foam is included on the inside of the microphone. Overall, it reduces the penetration of air shocks to the microphone, which optimises the call quality.
Jabra BIZ 2300 QD Duo - headset
Headset - wired
Recommended Use
Phone
United Kingdom, EMEA
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Microphone
Boom
Headset
68 g
Recommended Use
Phone
Headphones
Supraaural
Wired
Sound Output Mode
Stereo
Microphone
Boom
Connector Type
Headset (Quick Disconnect)
Headset cable
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 50 - 100
