The Jabra GN1900 USB delivers professional performance and exceptional value. It's the cost-effective headset investment decision that doesn't compromise on quality. Designed for contact center use, the Jabra GN1900 USB increases agent productivity and performance. Its noise canceling microphone ensures that background noise from your work environment won't be transmitted to your customers' ears.
The headset comes complete with USB plug for instant PC connectivity. Simply connect the headset to the computer and you're ready to profit from the Jabra GN1900 USB's low cost of ownership.
This is a USB connection only
Crystal clear conversations
Jabra's Biz 1900 may be designed with cost in mind, but it doesn't compromise on sound quality. Its flexible boom tip ensures perfect microphone placement while its noise-cancelling microphone eliminates ambient noise. Never compromise on voice quality – no matter what your budget. -
Easy integration with existing telecom systems
The Jabra Biz 1900 was designed for maximum flexibility and value: choose from QD Quick Disconnect or USB plug connections and duo or mono. However you work, the Jabra Biz 1900 will fit your infrastructure and your budget. -
Lightweight, sturdy design and professional quality
Professional agents need professional tools, no matter what the budget constraints are – and Jabra's Biz 1900 is built for heavy use. Key features include professional grade durability, leatherette ear cushions, a fully adjustable headband and the agent's choice of mono or duo wearing styles. -
Optimised for the cost-conscious contact centre
The Jabra Biz 1900 was designed with the cost-conscious contact centre in mind: purely functional, flexible, and value priced – quality without compromise from a brand you trust.
- Jabra GN1900 USB Duo - headset
- Product Type
- Headset - wired
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Mute, volume
- 2-year warranty
- Product Type
- Headset - wired
- 40 g
Audio Output
- On-ear binaural
- Wired
- Sound Output Mode
- Stereo
Microphone
- Boom
- Mono
Remote Control
- Controls
- Mute, volume
- Connector Type
- Headset (4 PIN USB Type A)
- Cable Details
- Headset cable
- Limited warranty - 2 years
