Jabra BIZ 1900 Duo USB Headset
Quicklinx: 6N8YWS00 Mfr#: 1989-829-104
The Jabra GN1900 USB delivers professional performance and exceptional value. It's the cost-effective headset investment decision that doesn't compromise on quality. Designed for contact center use, the Jabra GN1900 USB increases agent productivity and performance. Its noise canceling microphone ensures that background noise from your work environment won't be transmitted to your customers' ears.
The headset comes complete with USB plug for instant PC connectivity. Simply connect the headset to the computer and you're ready to profit from the Jabra GN1900 USB's low cost of ownership.
This is a USB connection only
  • Crystal clear conversations
    Jabra's Biz 1900 may be designed with cost in mind, but it doesn't compromise on sound quality. Its flexible boom tip ensures perfect microphone placement while its noise-cancelling microphone eliminates ambient noise. Never compromise on voice quality – no matter what your budget.
  • Easy integration with existing telecom systems
    The Jabra Biz 1900 was designed for maximum flexibility and value: choose from QD Quick Disconnect or USB plug connections and duo or mono. However you work, the Jabra Biz 1900 will fit your infrastructure and your budget.
  • Lightweight, sturdy design and professional quality
    Professional agents need professional tools, no matter what the budget constraints are – and Jabra's Biz 1900 is built for heavy use. Key features include professional grade durability, leatherette ear cushions, a fully adjustable headband and the agent's choice of mono or duo wearing styles.
  • Optimised for the cost-conscious contact centre
    The Jabra Biz 1900 was designed with the cost-conscious contact centre in mind: purely functional, flexible, and value priced – quality without compromise from a brand you trust.
Jabra GN1900 USB Duo - headset
Headset - wired
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Mute, volume
Headset - wired
40 g
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Microphone
Boom
Mono
Remote Control
Controls
Mute, volume
Connector Type
Headset (4 PIN USB Type A)
Cable Details
Headset cable
