Jabra BIZ 1500 Duo NC Headset
Quicklinx: C1ZKWS00 Mfr#: 1519-0154
Recommended Use: Phone, Phone
Connectivity: Wired
Earcover : Binaural
More than 50 in stock
£45.27 ex VAT
£54.32 inc VAT
The Jabra BIZ 1500 is an entry level, low-cost, professional corded headset with Jabra’s leading noise-cancellation technology. Designed for comfortable all-day wear.
Great sound
  • Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
  • HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
  • Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
  • Headband and microphone boom can be adjusted to suit your preference.
Tough Design
  • Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking
  • Great sound
    Noise-cancelling air shock microphone reduces background noise and sharp breathing sounds - ideal for crowded open offices. HD Voice makes your conversations sound vibrant and lifelike.
  • All-day comfort
    Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears. Headband and microphone boom can be adjusted to suit your preference.
Jabra BIZ 1500 Duo - headset
Headset - wired - Quick Disconnect
Recommended Use
Phone
EMEA
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
Impedance
150 Ohm
Max Input Power
30 mW
Microphone
Boom
13.1 cm
5.7 cm
16.5 cm
115 g
Earpad Material
Foam
Recommended Use
Phone
EMEA
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 4500 Hz
Max Input Power
30 mW
Sensitivity
115.5 dB/mW
Impedance
150 Ohm
Microphone
Boom
Sensitivity
-32 dBV/Pascal
Frequency Response
1000 - 5000 Hz
Audio Input Details
Uni-directional - 1000 - 5000 Hz
Connector Type
Headset (Quick Disconnect)
Cable
Cable Length
95 cm
Cable Details
Headset cable - 95 cm
C1ZK Jabra GN1200 Smartcord (Curly) - for Desk Phone Connectivity In Stock £19.37
C1ZK Jabra LINK 230 QD - USB Adapter In Stock £26.09
C1ZK Jabra Smart Cord GN1218, QD To RJ9 For Jabra QD Headsets In Stock £12.84
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
Price Range Ex VAT: 0 - 50
