istorage diskAshur2 SSD 256-bit 512GB - Black
Quicklinx: CX71WS00 Mfr#: IS-DA2-256-SSD-512-B
Capacity: 512GB
Interface: USB 3.1
Type: External hard drive
Hurry, only 1 left in stock!
£189.58 ex VAT
£227.49 inc VAT
Marketing description is not available.
  • Self-destruct feature
    You can pre-program the diskAshur2 with your own unique self-destruct PIN, which once implemented, instantly deletes the encryption key, all PINs, data and then creates a new encryption key.
  • Auto lock
    The diskAshur2 automatically locks when unplugged from the host computer or power to the USB port is turned off and can also be set to automatically lock after a predetermined amount of time.
  • Data at rest protection
    All data and encryption keys are always encrypted whilst at rest.
  • Wear resistant epoxy coated keypad
    Designed with protection in mind, the diskAshur2 wear resistant epoxy coated keypad hides key usage to avoid tipping off a potential hacker to commonly used keys.
iStorage diskAshur² - solid state drive - 512 GB - USB 3.1
Solid state drive - external (portable) - Wear Resistant Keypad, Brute Force Hack Defence Mechanism, OS & platform independent
512 GB
Hardware Encryption
Encryption Algorithm
FIPS 197, 256-bit AES-XTS
USB 3.1
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
Phantom black
84 mm x 124 mm x 19 mm
180 g
3-year warranty
512 GB
Hardware Encryption
USB 3.1
84 mm
124 mm
19 mm
180 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Internal Data Rate
294 MBps (read) / 319 MBps (write)
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 9 pin USB Type B
Power Source
USB bus
Carrying case
1 x USB 3.1 cable - integrated
FCC, RoHS, WEEE
Enclosure Colour
Phantom black
TAA Compliant
Limited warranty - 3 years
Capacity: 512GB
Interface: USB 3.1
Brand: istorage
Price Range Ex VAT: 150 - 300
