istorage diskAshur2 SSD 256-bit 1TB - Black
Quicklinx: CX72WS00 Mfr#: IS-DA2-256-SSD-1000-B
Capacity: 1TB, 1TB
Interface: USB 3.1
Type: External hard drive
£264.92 ex VAT
£317.90 inc VAT
Looking for an effortless way to secure your data while taking advantage of the fastest USB 3.0 speeds? Look no further than the diskAshur, the fast of iStorage's secure drive line. With the same easy-to-use keypad design and software free setup, the diskAshur enables you to access the drive with your own unique pin but now at data transfer speeds of up to 5 Gbps.
  • Self-destruct feature
    You can pre-program the diskAshur2 with your own unique self-destruct PIN, which once implemented, instantly deletes the encryption key, all PINs, data and then creates a new encryption key.
  • Auto lock
    The diskAshur2 automatically locks when unplugged from the host computer or power to the USB port is turned off and can also be set to automatically lock after a predetermined amount of time.
  • Data at rest protection
    All data and encryption keys are always encrypted whilst at rest.
  • Wear resistant epoxy coated keypad
    Designed with protection in mind, the diskAshur2 wear resistant epoxy coated keypad hides key usage to avoid tipping off a potential hacker to commonly used keys.
iStorage diskAshur² - solid state drive - 1 TB - USB 3.1
Solid state drive - external (portable) - Wear Resistant Keypad, Brute Force Hack Defence Mechanism, OS & platform independent
1 TB
Hardware Encryption
Encryption Algorithm
FIPS 197, 256-bit AES-XTS
USB 3.1
Data Transfer Rate
5.0 Gbps (USB 3.0)
Wear Resistant Keypad, Brute Force Hack Defence Mechanism, OS & platform independent, 256-bit AES-XTS
Power Source
USB bus
Enclosure Colour
Phantom black
84 mm x 124 mm x 20 mm
180 g
3-year warranty
1 TB
Hardware Encryption
USB 3.1
84 mm
124 mm
20 mm
180 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Internal Data Rate
294 MBps (read) / 319 MBps (write)
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows
Carrying case
1 x USB 3.1 cable - integrated
FCC, RoHS, WEEE
Enclosure Colour
Phantom black
TAA Compliant
Limited warranty - 3 years
Capacity: 1TB
Capacity: 1TB
Interface: USB 3.1
Brand: istorage
Price Range Ex VAT: 150 - 300
