istorage diskAshur2 SSD 256-bit 128GB - Black
Quicklinx: CX6ZWS00 Mfr#: IS-DA2-256-SSD-128-B
Capacity: 128GB
Interface: USB 3.1
Type: External hard drive
£112.22 ex VAT
£134.66 inc VAT
Looking for an effortless way to secure your data while taking advantage of the fastest USB 3.0 speeds? Look no further than the diskAshur, the fast of iStorage's secure drive line. With the same easy-to-use keypad design and software free setup, the diskAshur enables you to access the drive with your own unique pin but now at data transfer speeds of up to 5 Gbps.
  • Software free design
    With no software installation required for setup or operation and the ability to run on any platform, the iStorage diskAshur provides stress free deployment in corporate environments. Its administrator feature allows enrollment of up to five unique user IDs and one administrator, making it a useful business collaboration tool.
  • Super fast USB 3.0 connection
    Data transfer speeds up to 10x faster than USB 2.0: with a super speed USB 3.0 interface, you can now access your files faster than ever before. The diskAshur is also backwards compatible with USB 2.0 and 1.1 ports.
  • Brute Force Self Destruct feature
    The iStorage diskAshur uses a three pronged approach to protect against a Brute Force attack. The first step is to deny access to the drive until the drive can verify the user PIN. After six incorrect attempts the drive will lock itself, requiring the drive to be plugged in again to input a PIN. This feature blocks automated attempts to enter PIN numbers. Lastly, after a predetermined number of failed PIN entries, the diskAshur assumes it is being attacked and will destroy the encryption key and lock itself, rendering the data useless and requiring a total reset to redeploy the diskAshur.
  • Drive reset feature
    The diskAshur also employs a useful drive reset feature, which can be implemented with a unique command. This clears all PINs and data, and creates a randomly generated encryption key, enabling the drive to be reset and redeployed as many times as needed.
  • Auto-lock feature
    The unattended diskAshur can be configured to lock after a pre-determined amount of time of your choosing. It is ideal for protecting your data when you're away from your desk.
  • Compact, rugged design
    Perfect for taking your data on the road, the diskAshur's low powered design is perfect for using with notebooks and taking your data on the road. Perfectly pocketable, the diskAshur's compact, robust design features a 16-point omni-directional shock mounting system and rubberized paint, protecting the drive from drops and knocks. The convenient integrated USB 3.0 cable eliminates the need to carry around cords with you and allows you to be connected at the flick of a fingertip.
iStorage diskAshur 2 - solid state drive - 128 GB - USB 3.1
Solid state drive - external (portable) - Wear Resistant Keypad, Brute Force Hack Defence Mechanism, OS & platform independent
128 GB
Hardware Encryption
Encryption Algorithm
FIPS 197, 256-bit AES-XTS
USB 3.1
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
Phantom black
84 mm x 124 mm x 19 mm
180 g
3-year warranty
128 GB
Hardware Encryption
USB 3.1
84 mm
124 mm
19 mm
180 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Internal Data Rate
294 MBps (read) / 319 MBps (write)
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 9 pin USB Type B
Power Source
USB bus
Carrying case
1 x USB 3.1 cable - integrated
FCC, RoHS, WEEE
Enclosure Colour
Phantom black
TAA Compliant
Limited warranty - 3 years
Capacity: 128GB
Interface: USB 3.1
Brand: istorage
Price Range Ex VAT: 100 - 150
