istorage diskAshur USB3 256-bit 250GB
Quicklinx: 84KNWS00 Mfr#: IS-DG3-256-250
Looking for an effortless way to secure your data while taking advantage of lightning fast USB 3.0 speeds? Look no further than the iStorage diskAshur 3.0, the latest addition to the iStorage family of ultra-secure, easy to use and affordable products.
With the same easy-to-use keypad design and software free setup, the iStorage diskAshur 3.0 enables you to access the drive with your own unique pin, but now at data transfer speeds of up to 10x faster than USB 2.
  • Software free design
    With no software installation required for setup or operation and the ability to run on any platform, the iStorage diskAshur provides stress free deployment in corporate environments. Its Administrator feature allows enrollment of up to five unique user IDs and one administrator, making it a useful business collaboration tool.
  • Super fast USB 3.0 connection
    Data transfer speeds up to 10x faster than USB 2.0: with a super speed USB 3.0 interface, you can now access your files faster than ever before. The diskAshur is also backwards compatible with USB 2.0 and 1.1 ports.
  • Brute Force Self Destruct feature
    The iStorage diskAshur uses a three pronged approach to protect against a Brute Force attack. The first step is to deny access to the drive until the drive can verify the user PIN. After six incorrect attempts the drive will lock itself, requiring the drive to be plugged in again to input a PIN. This feature blocks automated attempts to enter PIN numbers. Lastly, after a predetermined number of failed PIN entries, the diskAshur assumes it is being attacked and will destroy the encryption key and lock itself, rendering the data useless and requiring a total reset to redeploy the diskAshur.
  • Drive reset feature
    The diskAshur also employs a useful drive reset feature, which can be implemented with a unique command. This clears all PINs and data, and creates a new randomly generated encryption key, enabling the drive to be reset and redeployed as many times as needed.
  • Auto-lock feature
    The unattended diskAshur can be configured to lock after a pre-determined amount of time of your choosing. Ideal for protecting your data when you're away from your desk.
  • Compact, rugged design
    Perfect for taking your data on the road, the diskAshur's low powered design is perfect for using with notebooks and taking your data on the road. Perfectly pocketable, the diskAshur's compact, robust design features a 16-point omni-directional shock mounting system and rubberized paint, protecting the drive from drops and knocks. The convenient integrated USB 3.0 cable eliminates the need to carry around cords with you and allows you to be connected at the flick of a fingertip.
iStorage diskAshur - hard drive - 250 GB - USB 3.0
Hard drive - external (portable) - shock resistant, built-in keypad, password authentication, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset
250 GB
Encryption Algorithm
FIPS 197
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, password authentication, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, 256-bit AES
Power Source
USB bus
8.5 cm x 12 cm x 1.9 cm
176 g
3-year warranty
250 GB
FIPS 197
USB 3.0
Buffer Size
8 MB
8.5 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows
Carrying case
1 x USB 3.0 cable - integrated , 1 x USB cable - external
FCC, RoHS, WEEE
Limited warranty - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
