Looking for the highest level of security for your data while utilizing the fastest USB 3.0 speeds?
Look no further than the iStorage diskAshur Pro, certified and tested to NIST FIPS 140-2 Level 2 requirements. Sporting an easy-to-use keypad design that is impervious to dust and grit, a software free setup and operation, the diskAshur Pro enables you to access the drive simply and easily with your own unique PIN and with a super fast integrated USB 3.0 cable, you can access your data faster than ever before!
- iStorage diskAshur Pro - solid state drive - 512 GB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 512 GB
- Encryption Algorithm
- FIPS 140-2 Level 2
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Shock resistant, water resistant, built-in keypad, password authentication, dust-proof, Variable Time Circuit (VTC) technology, auto lock, Data at Rest Protection, drive reset, Wear Resistant Keypad, Brute-Force Password Attack Protection, 256-bit AES-XTS
- Power Source
- USB bus
- 84.5 mm x 120 mm x 19 mm
- 190 g
- 2 years warranty
- Capacity
- 512 GB
- Interface
- USB 3.0
- 84.5 mm
- 120 mm
- 19 mm
- 190 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Power Source
- USB bus
- OS Required
- Linux, Apple MacOS X 10.2.x or later, Microsoft Windows Vista / XP / 7 / 8
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium RAM 32 MB , MacOS X 10.2.x or later - PowerPC G3 RAM 32 MB
- Included Accessories
- Carrying pouch
- Cables Included
- 1 x USB 3.0 cable - integrated , 1 x USB power splitter cable - external
- Limited warranty - 2 years
- Shock Tolerance
- 300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
