Product
Brand
istorage DiskAshur Pro 1TB USB 3.0 SSD Pin Access
Quicklinx: B61BWS00 Mfr#: IS-DP3-256-SSD-1000F
Looking for the highest level of security for your data while utilizing the fastest USB 3.0 speeds?
Look no further than the iStorage diskAshur Pro, certified and tested to NIST FIPS 140-2 Level 2 requirements. Sporting an easy-to-use keypad design that is impervious to dust and grit, a software free setup and operation, the diskAshur Pro enables you to access the drive simply and easily with your own unique PIN and with a super fast integrated USB 3.0 cable, you can access your data faster than ever before!
iStorage diskAshur Pro - solid state drive - 1 TB - USB 3.0
Solid state drive - external (portable)
1 TB
Encryption Algorithm
FIPS 140-2 Level 2, FIPS 197
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Water resistant, built-in keypad, dust-proof, Variable Time Circuit (VTC) technology, auto lock, Data at Rest Protection, drive reset, Wear Resistant Keypad, Brute-Force Password Attack Protection, Self Destruct PIN, 256-bit AES-XTS
Power Source
USB bus
84.5 mm x 120 mm x 19 mm
190 g
3 years warranty
1 TB
USB 3.0
Buffer Size
8 MB
84.5 mm
120 mm
19 mm
190 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
0.1 ms (average)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows, Android
Carrying pouch
1 x USB 3.0 cable - integrated , 1 x USB power splitter cable - external
FCC, RoHS
Limited warranty - 3 years
