istorage diskAshur DT2 256-bit 8TB - Classified - Graphite
Quicklinx: CX8KWS00 Mfr#: IS-DT2-256-8000-C-G
Capacity: 8TB
Hurry, only 3 left in stock!
£421.73 ex VAT
£506.07 inc VAT
The iStorage desktop secure hard drive utilizes military grade AES 256-bit hardware encryption, which encrypts all data stored on the drive in real time. Should the drive be lost or stolen, the user can rest assured that all data held on the drive is safe and cannot be accessed by any unauthorized third party, even if the hard drive is removed from its enclosure.
  • EDGETM (Enhanced Dual Generating Encryption) technology
    Offering advanced portable data security via built-in FIPS PUB 197 validated AES 256-bit XTS hardware encryption engine. The data encryption key is randomly generated by a Common Criteria EAL4+ ready Random Number Generator and protected by NCSC, FIPS and Common Criteria validated wrapping algorithms. Uniquely featuring a dedicated onboard Common Criteria EAL4+ ready secure microprocessor to enhance security through true random number generation and built-in cryptography. The security component employs physical protection mechanisms to protect itself from any external tamper, bypass laser attacks and fault injections and incorporates active-shield violation technology. More specifically, the secure microprocessor reacts to all forms of automated hacking attempts by entering the deadlock frozen state where the device can only restart through a "Power On" Reset procedure (i.e. power off/power on). The security lock feature protects the device against any unauthorized firmware modifications from the host side (fully protected against BadUSB). The diskAshur DT2 uniquely incorporates a secure microprocessor providing secure algorithms to encrypt both the data and the encryption key, giving you confidence that your data is protected to the highest standards at any given time.
  • FIPS PUB 197 validated encryption algorithm
    Employing AES-XTS 256-bit hardware encryption, the iStorage diskAshur DT2 seamlessly encrypts all data on the drive in real-time, keeping your data safe even if the hard drive is removed from its enclosure.
  • Super-fast USB 3.1
    With super-fast USB 3.1 data transfer speeds of 225 MBps (Read) and 223 MBps (Write), you can now access your files faster than ever before. The iStorage diskAshur DT2 is also backwards compatible with USB 2.0 and 1.1 ports.
  • Brute force hack defense mechanism
    The iStorage diskAshur DT2 is intelligently programmed to protect against all forms of Brute Force attacks. After five consecutive incorrect PIN entries, the drive will freeze, requiring the drive to be powered off and powered back on again in order to get a further five PIN entry attempts. If a further five (10 in total) consecutive incorrect PIN attempts are entered again, the diskAshur DT2 will freeze again. To get a further and final five PIN attempts (15 in total), the "shift" button must be pressed whilst powering the diskAshur DT2 off and then powering back on before entering the iStorage preset PIN. On the fifteenth consecutive incorrect PIN entry, the diskAshur DT2 assumes it is being attacked and will delete the encryption key and lock itself, rendering all data previously stored on the drive as lost forever. At this point, the drive can be reset to factory default settings and redeployed.
iStorage diskAshur DT 2 - hard drive - 8 TB - USB 3.1
Hard drive - external (portable) - Wear Resistant Keypad, Brute Force Hack Defence Mechanism, government certified, OS & platform independent
8 TB
Hardware Encryption
Encryption Algorithm
FIPS 197, 256-bit SHA, 256-bit AES-XTS
USB 3.1
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
112 mm x 185.5 mm x 43.5 mm
1.238 kg
8 TB
Hardware Encryption
USB 3.1
112 mm
185.5 mm
43.5 mm
1.238 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Internal Data Rate
225 MBps (read) / 223 MBps (write)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B
Power Source
USB bus
Power adapter
DC 12 V
USB cable
FCC, RoHS, WEEE
TAA Compliant
Capacity: 8TB
Brand: istorage
Price Range Ex VAT: 300 - 500
