The iStorage desktop secure hard drive utilizes military grade AES 256-bit hardware encryption, which encrypts all data stored on the drive in real time. Should the drive be lost or stolen, the user can rest assured that all data held on the drive is safe and cannot be accessed by any unauthorized third party, even if the hard drive is removed from its enclosure.
- iStorage diskAshur DT - hard drive - 8 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 8 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES, FIPS 197
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Buffer Size
- 8 MB
- Spindle Speed
- 5900 rpm
- Built-in keypad, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Wear Resistant Keypad, NTFS formatted, on/off switch, PIN code authentication, 256-bit AES
- Power Source
- Included AC adapter
- 11.43 cm x 18.288 cm x 3.81 cm
- 2-year warranty
- Capacity
- 8 TB
- Interface
- USB 3.0
- Buffer Size
- 8 MB
- 11.43 cm
- 18.288 cm
- 3.81 cm
Performance
- Interface Transfer Rate
- Seek Time
- 12 ms (average)
- Spindle Speed
- 5900 rpm
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type B
- Power Source
- Power Device
- Power adapter
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
- Cables Included
- 1 x USB cable - external
- Enclosure Material
- Aluminium
- FCC, RoHS, WEEE
- Limited warranty - 2 years
- Shock Tolerance (operating)
- 300 g @ 2 ms
- Shock Tolerance (non-operating)
- 1000 g @ 1 ms
