Your basket is empty
iStorage datAshur SSD USB flash drive - encrypted - 240 GB - USB 3.0 - FIPS 140-2 Level 3
Quicklinx: BBJPWS00 Mfr#: IS-FL-DA-SSD-240
With the datAshur SSD's advanced security features such as read-only mode, auto-lock, self-destruct PIN and brute force protection, delivers complete data security and guarantees 100% protection of your data.
iStorage datAshur SSD - USB flash drive - 240 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
240 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, FIPS 197, 256-bit SHA, 256-bit AES-XTS
Apple MacOS, Linux, Microsoft Windows, Android
3 years warranty
USB flash drive
Storage Capacity
240 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 195 MB/s
Write Rate
Up to 162 MB/s
Interface Type
USB 3.0
Water resistant, dustproof, auto-locking, customizable PIN, ruggedized, Read-Only Access Mode, brute-force protection, Self-Destruct PIN, boot delay, drive reset, Onboard Alphanumeric Keypad, Lock Override Mode, epoxy internal filling
Protective sleeve
Plug and Play, FCC, RoHS, IP57, IP58
Limited warranty - 3 years
24.5 mm
12.6 mm
93 mm
46 g
