Product
istorage 4TB diskAshur 256-bit USB 3.0 3.5" Desktop Hard Drive
Quicklinx: 9RJXWS00 Mfr#: IS-DA-256-4000
The iStorage desktop secure hard drive utilizes military grade AES 256-bit hardware encryption, which encrypts all data stored on the drive in real time. Should the drive be lost or stolen, the user can rest assured that all data held on the drive is safe and cannot be accessed by any unauthorized third party, even if the hard drive is removed from its enclosure.
iStorage diskAshur DT - hard drive - 4 TB - USB 3.0
Hard drive - external (desktop)
4 TB
Hardware Encryption
Encryption Algorithm
FIPS 197
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
7200 rpm
Built-in keypad, password authentication, hardware encryption, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, 256-bit AES
Power Source
Included AC adapter
11.43 cm x 18.288 cm x 3.81 cm
3 years warranty
4 TB
Hardware Encryption
FIPS 197
USB 3.0
Buffer Size
8 MB
11.43 cm
18.288 cm
3.81 cm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
12 ms (average)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
FCC, RoHS
Limited warranty - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
