The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
- iStorage datAshur Personal - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 32 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES, FIPS 197, 256-bit SHA
- Enclosure Colour
- Blue
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Android
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Enclosure Colour
- Blue
- Read Rate
- Up to 27 MB/s
- Write Rate
- Up to 24 MB/s
- Interface Type
- USB 2.0
- USB On-The-Go compatible, auto-locking, tamper-proof, 10 Key PIN pad, Brute Force Hack Defence Mechanism, DataLock technology
- FCC, RoHS, WEEE
- OS Required
- Limited warranty - 3 years
- 17.4 mm
- 83 mm
- 8.6 mm
- 20 g
