Product
istorage 32GB datAshur Personal 256-bit USB Drive - Dark Blue
Quicklinx: 9KKTWS00 Mfr#: IS-FL-DAP-DB-32
Capacity: 32GB
Interface: USB 2.0
12 in stock
£55.77 ex VAT
£66.92 inc VAT
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur Personal - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES, FIPS 197, 256-bit SHA
Enclosure Colour
Blue
Apple MacOS, Linux, Microsoft Windows, Android
3 years warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
Enclosure Colour
Blue
Compatibility
Non-specific
Read Rate
Up to 27 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
USB On-The-Go compatible, auto-locking, tamper-proof, 10 Key PIN pad, Brute Force Hack Defence Mechanism, DataLock technology
FCC, RoHS, WEEE
Limited warranty - 3 years
17.4 mm
83 mm
8.6 mm
20 g
Capacity: 32GB
Interface: USB 2.0
Brand: istorage
Price Range Ex VAT: 50 - 100
