Product
Brand
istorage 250GB diskGenie 256-bit 5400rpm 8MB USB 2.0 Encrypted HDD
Quicklinx: 7QQ4WS00 Mfr#: IS-DG-256-250
The iStorage diskG is the secure, compact and affordable USB 2.0 portable hard drive, employing PIN code access with 128-bit or 256-bit AES hardware encryption. The iStorage diskG utilizes military grade AES 128-bit or 256-bit hardware encryption, which encrypts ALL data stored on the drive in real time, making it as fast and in many cases faster than any non-encrypted USB 2.0 hard drive.
iStorage diskG IS-DG-256-250 - hard drive - 250 GB - USB 2.0
Hard drive - external (portable)
250 GB
Encryption Algorithm
FIPS 197
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, administrator password, auto lock, drive reset, Wear Resistant Keypad, 256-bit AES
Power Source
USB bus
8.45 cm x 12 cm x 1.9 cm
176 g
3 years warranty
250 GB
FIPS 197
USB 2.0
Buffer Size
8 MB
8.45 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
480 Mbps
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2 or later, Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium RAM 32 MB , MacOS X 10.2 or later - PowerPC G3
Carrying case
1 x USB cable - integrated
Plug and Play, FCC, RoHS, WEEE, CESG Claims Tested Mark (CCTM)
Limited warranty - parts and labour - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
