Looking for an effortless way to secure your data while taking advantage of lightning fast USB 3.0 speeds? Look no further than the iStorage diskAshur 3.0, the latest addition to the iStorage family of ultra-secure, easy to use and affordable products.
With the same easy-to-use keypad design and software free setup, the iStorage diskAshur 3.0 enables you to access the drive with your own unique pin but now at data transfer speeds of up to 10x faster than USB 2.
Software free design
With no software installation required for setup or operation and the ability to run on any platform, the iStorage diskAshur SSD provides stress free deployment in corporate environments. Its Administrator feature allows enrollment of up to five unique user IDs and one administrator, making it a useful business collaboration tool. -
Super fast USB 3.0 connection
Data transfer speeds up to 10x faster than USB 2.0: with a super speed USB 3.0 interface, you can now access your files faster than ever before. The diskAshur SSD is also backwards compatible with USB 2.0 and 1.1 ports. -
Brute Force Self Destruct feature
The iStorage diskAshur SSD uses a three pronged approach to protect against a Brute Force attack. The first step is to deny access to the drive until the drive can verify the user PIN. After six incorrect attempts the drive will lock itself, requiring the drive to be plugged in again to input a PIN. This feature blocks automated attempts to enter PIN numbers. Lastly, after a predetermined number of failed PIN entries, the diskAshur SSD assumes it is being attacked and will destroy the encryption key and lock itself, rendering the data useless and requiring a total reset to redeploy the diskAshur SSD. -
Drive reset feature
The diskAshur SSD also employs a useful drive reset feature, which can be implemented with a unique command. This clears all PINs and data, and creates a new randomly generated encryption key, enabling the drive to be reset and redeployed as many times as needed. -
Auto-lock feature
The unattended diskAshur SSD can be configured to lock after a pre-determined amount of time of your choosing. Ideal for protecting your data when you're away from your desk. -
Compact, rugged design
Perfect for taking your data on the road, the diskAshur SSD's low powered design is perfect for using with notebooks and taking your data on the road. Perfectly pocketable, the diskAshur SSD's compact, robust design features a 16-point omni-directional shock mounting system and rubberized paint, protecting the drive from drops and knocks. The convenient integrated USB 3.0 cable eliminates the need to carry around cords with you and allows you to be connected at the flick of a fingertip.
- iStorage diskAshur - SSD - 240 GB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 240 GB
- Encryption Algorithm
- FIPS 197
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Shock resistant, built-in keypad, password authentication, vibration dampening, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, 256-bit AES
- Power Source
- USB bus
- 8.5 cm x 12 cm x 1.9 cm
- 176 g
- 3-year warranty
- Capacity
- 240 GB
- FIPS 197
- Interface
- USB 3.0
- 8.5 cm
- 12 cm
- 1.9 cm
- 176 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type A
- Power Source
- USB bus
- OS Required
- Linux, Apple MacOS X 10.2.x or later, Microsoft Windows Vista / XP / 7
- System Requirements Details
- Windows XP/Vista/7 - Pentium RAM 32 MB , MacOS X 10.2 or later - PowerPC G3
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB 3.0 cable - integrated , 1 x power cable - external
- Plug and Play, FCC, RoHS, WEEE, CESG Claims Tested Mark (CCTM)
- Limited warranty - parts and labour - 3 years
- 0 °C
- 70 °C
- 0 - 95%
- Shock Tolerance
- 1500 g @ 0.5ms
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
