The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
- iStorage datAshur - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES, 256-bit SHA
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Symbian OS, Android
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Read Rate
- Up to 27 MB/s
- Write Rate
- Up to 24 MB/s
- Interface Type
- USB 2.0
- Brute Force Hack Defence Mechanism, wear-resistant keypad, government certified, OS & platform independent
- Included Accessories
- Protective sleeve
- Plug and Play, FCC, RoHS, WEEE, MIL-STD-810F
- OS Required
- Limited warranty - 3 years
- 78 mm
- 18 mm
- 10.5 mm
- 25 g
