Your basket is empty
Iron Key Basic H300 1TB Hard Drive USB 3.0 FIPS 140-2 Level 3
Quicklinx: C5SPWS00 Mfr#: MXKB1B001T5001-B
High-Security USB 3.0 SuperSpeed Hard Drives for the Enterprise and Public Sector. Each IronKey Basic H300 hard drive is encased in a high-strength aluminum enclosure and features AES 256-bit hardware encryption implemented using tamper-resistant technologies to withstand the most determined hackers. Enterprise and government agencies can get world-renowned IronKey security at a competitive price with the next generation hard drives that store up to 1TB of data.
IronKey Basic H300 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, zero footprint mode, hardware encryption, auto lock, aluminium enclosure, tamper-resistant, 256-bit AES-XTS
Power Source
USB bus
86.6 mm x 124.6 mm x 26.8 mm
5 years warranty
1 TB
Hardware Encryption
FIPS 140-2 Level 3
USB 3.0
86.6 mm
124.6 mm
26.8 mm
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
IronKey Control Panel
Apple MacOS X 10.6 or later, Linux 2.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
VCCI, C-Tick, BSMI, ICES-003, FCC, RoHS, KCC, WEEE, Section 508
TAA Compliant
Limited warranty - 5 years
