Scanning has never been simpler thanks to the all-in-one scanner and mouse IRIScan Mouse; the scanner lies at your fingertips all day long! Click on the scan button, swipe in any direction on a document and watch texts and images appear instantaneously on your screen.
A scanner at your fingertips
Scanning has never been simpler thanks to the all-in-one scanner and mouse IRIScan Mouse; the scanner lies at your fingertips all day long! Click on the scan button, swipe in any direction on a document and watch texts and images appear instantaneously on your screen. -
Never retype any text again
Thanks to I.R.I.S. OCR technology, any texts on the image you scanned is recognized; simply drag and drop them into Microsoft Office edit and upload to the Cloud in a click.
- IRIS IRIScan Mouse - hand-held scanner - handheld - USB 2.0
- Hand-held scanner - handheld
- Interface Type
- USB 2.0
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Optical Resolution
- 400 dpi
- Max Document Size
- 297 mm x 420 mm
- Supported Document Type
- Plain paper
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- 3.63 cm x 6.15 cm x 0.99 cm
- 108 g
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- 400 dpi
- Control Panel Buttons Functions
- Scan
Media Handling
- Max Document Size
- 297 mm x 420 mm
- Plain paper
- Interfaces Details
- USB 2.0
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable
- Power Consumption Operational (Standby)
- 0.625 Watt
- Software Included
- Drivers & Utilities, Evernote Premium (3-month subscription), IRISCompressor
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Core 2 Duo - 1.2 GHz - RAM 1 GB - HD 1 GB (USB 2.0) , Windows XP/Vista/7/8 - Athlon 64 X2 - 1.7 GHz - RAM 1 GB - HD 1 GB (USB 2.0)
- 3.63 cm
- 6.15 cm
- 0.99 cm
- 108 g
