Your basket is empty
IRIS IRIScan Mouse Hand-Held Scanner
Quicklinx: BLNGWS00 Mfr#: 457885
Scanning has never been simpler thanks to the all-in-one scanner and mouse IRIScan Mouse; the scanner lies at your fingertips all day long! Click on the scan button, swipe in any direction on a document and watch texts and images appear instantaneously on your screen.
IRIS IRIScan Mouse - hand-held scanner - handheld - USB 2.0
Hand-held scanner - handheld
Interface Type
USB 2.0
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Optical Resolution
400 dpi
Max Document Size
297 mm x 420 mm
Supported Document Type
Plain paper
Microsoft Windows Vista / XP / 7 / 8
3.63 cm x 6.15 cm x 0.99 cm
108 g
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Optical Resolution
400 dpi
Control Panel Buttons Functions
Scan
Media Handling
Max Document Size
297 mm x 420 mm
Plain paper
USB 2.0
Carrying case
1 x USB cable
Power Consumption Operational (Standby)
0.625 Watt
Software Included
Drivers & Utilities, Evernote Premium (3-month subscription), IRISCompressor
System Requirements Details
Windows XP/Vista/7/8 - Core 2 Duo - 1.2 GHz - RAM 1 GB - HD 1 GB (USB 2.0) , Windows XP/Vista/7/8 - Athlon 64 X2 - 1.7 GHz - RAM 1 GB - HD 1 GB (USB 2.0)
3.63 cm
6.15 cm
0.99 cm
108 g
