Your basket is empty
ioSafe Solo PRO External Hard Drive 3TB 3.5" USB 3.0 with 1 year Pro Data Recovery Service
Quicklinx: BX4QWS00 Mfr#: SM3TB1YR
DataCast endothermic fire insulation technology protects your data from extreme heat. The DataCast formulation forms a chemical bond with water molecules that, at temperatures above 160°F, releases water vapor to limit the internal temperature of the unit during a fire.
HydroSafe water barrier technology is designed to protect data loss from fresh or salt water damage, including full immersion. While keeping your data dry, the HydroSafe technology still allows heat to dissipate during normal operation.
With high data transfer, the eSATA/USB2.0 SoloPRO combines internal drive performance and connectivity with the freedom of having external storage. The eSATA interface also provides plug and play connectivity to servers. With added Plug and Play USB 2.0 connectivity and high data transfer, you can use your ioSafe with virtually any Mac or PC.
ioSafe Solo PRO - hard drive - 3 TB - USB 3.0
Hard drive - external (desktop)
3 TB
3.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Security lock slot (cable lock sold separately), water resistant, fire resistant, cooling fan
Power Source
Included AC adapter
12.7 cm x 27.9 cm x 18 cm
6.8 kg
1 year warranty
Bundled with
3 TB
3.5"
USB 3.0
12.7 cm
27.9 cm
18 cm
6.8 kg
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
3.5"
Power Source
Included AC adapter
Power supply
(50/60 Hz)
Linux, Apple MacOS 8.6 or later, Microsoft Windows 7, Microsoft Windows Server 2008
System Requirements Details
Dual Pentium 4 - 350 MHz
1 x USB cable
UL, FCC, ASTM
Limited warranty - 1 year
35 °C
20 - 80% (non-condensing)
