DataCast endothermic fire insulation technology protects your data from extreme heat. The DataCast formulation forms a chemical bond with water molecules that, at temperatures above 160°F, releases water vapor to limit the internal temperature of the unit during a fire.
HydroSafe water barrier technology is designed to protect data loss from fresh or salt water damage, including full immersion. While keeping your data dry, the HydroSafe technology still allows heat to dissipate during normal operation.
With high data transfer, the eSATA/USB2.0 SoloPRO combines internal drive performance and connectivity with the freedom of having external storage. The eSATA interface also provides plug and play connectivity to servers. With added Plug and Play USB 2.0 connectivity and high data transfer, you can use your ioSafe with virtually any Mac or PC.
Protects from fire
The SoloPro is designed to protect your hard drives from the punishing conditions of 1550° for 30 minutes, meaning that your data is safe from office or home fires. -
Waterproof and ready
To secure your data from a firefighter's hose or a leaky pipe, the SoloPro will protect its hard drives for up to 3 days when submerged to 10 feet. -
Cool and comfortable
The ioSafe SoloPro is fan-cooled for optimal drive performance and longevity. -
Business-class performance
The ioSafe SoloPro is designed for high performance and reliability, and is built to operate within the requirements of a high pressure business environment.
- ioSafe Solo PRO - hard drive - 2 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Security lock slot (cable lock sold separately), water resistant, fire resistant, cooling fan
- Power Source
- Included AC adapter
- 12.7 cm x 27.9 cm x 18 cm
- 6.8 kg
- 1-year warranty
- Bundled with
- 5 years Pro Data Recovery Service
- Capacity
- 2 TB
- Form Factor
- 3.5"
- Interface
- USB 3.0
- 12.7 cm
- 27.9 cm
- 18 cm
- 6.8 kg
- Bundled with
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 3.5"
- Power Source
- Power Device
- Power supply
- Voltage Required
- (50/60 Hz)
- OS Required
- Linux, Apple MacOS 8.6 or later, Microsoft Windows 7, Microsoft Windows Server 2008
- System Requirements Details
- Pentium II - 350 MHz
- Cables Included
- 1 x USB 3.0 cable
- UL, FCC, ASTM
- Limited warranty - 1 year
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
