Data has become increasingly mobile, but with that increased mobility comes increased risk. Delicate portable storage devices can easily be dropped during travel, stolen or exposed to adverse environmental conditions such as extreme temperatures, sand or moisture - all factors which can lead to data loss. The ioSafe Rugged Portable addresses each of these problems. It's tough enough to be used in arctic or desert environments, is shock and crush resistant, has anti-theft features.
Impact protection
Tested to military standard MIL-STD-810G 516.5. Full suspension in all size axes of motion delivers drop protection up to 10'. -
Immersion protection
HydroSafe technology protects data during immersion up to 3 days in fresh water or saltwater to a depth of 30'. Unlike other products, the Rugged Portable remains waterproof when the USB cable is connected. -
Crush protection
Full Metal Jacket technology: CNC-machined from a billet of solid aluminum, the Rugged Portable is crush-resistant to 2,500 lbs. -
Extreme environment protection
EnviroSafe technology protects data from exposure to UV, blowing sand, blowing dust, rain, salt fog, icing or freezing rain for up to 24 hours per MIL-STD-810G 505.4, 506.4, 509.4 and 510. -
Chemical protection
ChemSafe technology protects data during periods of immersion in diesel fuel, oils, hydraulic fluids and aircraft fuels to a 12' depth for 1 hour per MIL-STD-810G 504. -
Altitude protection
AltiSafe technology enables operation at altitudes up to 30,000 feet per MIL-STD-810G 500.4. -
SuperSpeed USB
USB 3.0 connectivity delivers blazingly fast transfer speeds up to 5 Gb/s and backwards compatibility with USB 2.0.
- ioSafe Rugged Portable - SSD - 1 TB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Security lock slot (cable lock sold separately), Full Metal Jacket, Full Suspension Drive, HydroSafe, ChemSafe, EnviroSafe, AltiSafe
- Power Source
- USB bus
- Enclosure Colour
- Anodized black
- 9.9 cm x 14.5 cm x 2.5 cm
- 453 g
- 1-year warranty
- Bundled with
- 1 year Data Recovery Service
- Capacity
- 1 TB
- Interface
- USB 3.0
- 9.9 cm
- 14.5 cm
- 2.5 cm
- 453 g
- Bundled with
Performance
- Interface Transfer Rate
- Power Source
- USB bus
- Software Included
- Apple Time Machine, Genie Timeline Professional
- OS Required
- Apple MacOS, Microsoft Windows
- System Requirements Details
- Pentium II - 350 MHz
- Cables Included
- 1 x USB 3.0 cable - external , 1 x USB power splitter cable - external
- Enclosure Material
- Aluminium
- MIL-STD 810G, IP68
- Enclosure Colour
- Anodized black
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
