With its fire/water protection, superior performance, scalability, resilience, and comprehensive features, ioSafe NAS 1515+ is the ideal storage solution for your growing business. Featuring hardware encryption engine, and flawless software integration, the ioSafe 1515+ is a powerful, expandable 5-bay NAS server that delivers outstanding speed and accelerated data encryption. The 1515+ can help to simplify disaster recovery, business continuity, data management, sharing storage for storage and backup - with minimal setup and the freedom to expand capacity at any time.
Ultimate security and protection
The ioSafe NAS 1515+ powered by Synology DSM is the ultimate in security because data remains local and is never exposed to the dangers on the traditional public cloud. All security details are 100% controlled by you - the person that cares the most about the data. -
Fast encrypted data transmission with AES-NI
Encrypting data is essential to a healthy security policy. Equipped with a dedicated hardware encryption engine, the ioSafe 1515+ is the ideal digital safe for sensitive data; files and folders are encrypted on the fly without any perceived performance loss. -
Quad LAN ports for failover and Link Aggregation support
Equipped with four Ethernet ports featuring failover and Link Aggregation support, ioSafe 1515+ ensures continual network uptime even if LAN connection malfunction occurs on one port, reducing the chance of service disruption and costly downtime. Link Aggregation improves connection speeds beyond the limits of a single network cable or port. -
Robust scalability
As your data storage needs grow, ioSafe 1515+ can be connected to dedicated expansion units for additional storage on the fly, growing capacity with minimal effort. With two expansion units connected through specially designed eSATA connectors. -
iSCSI and virtualization ready
With the iSCSI support in the Synology DSM platform, the 1515+ provides a seamless storage solution for virtualization servers, such as VMware, Hyper-V, and Citrix. It is the ideal alternative to SAN solution for businesses. Affordable and costeffective, iSCSI allows SMB users to consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks.
- ioSafe 1515+ - NAS server - 60 TB
- NAS server
- Bundled Services
- 1 year Data Recovery Service Basic
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 60 TB
- Installed Devices / Modules Qty
- 10 (installed) / 10 (max)
- 24.8 cm x 23.3 cm x 15.7 cm
- Processor
- 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 10 x 6 TB HydroSafe
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- 1-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 60 TB
- 24.8 cm
- 23.3 cm
- 15.7 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 10 x 6 TB
- HydroSafe
- Data Link Protocol
- PPTP, L2TP
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, LDAP support, wake on LAN (WOL), print server, web server, Access Control List (ACL) support, e-mail server, VPN Server
- Encryption Algorithm
- AES
- Expansion Bays
- 10 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x eSATA
- Security lock slot (cable lock sold separately), water-resistant, fire resistant, built-in 2 cooling fans, Citrix Ready
- Security Slot Type
- Kensington security slot
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Synology Assistant
- OS Required
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 5 - 95%
