Vinyl Transport is a classically-styled suitcase turntable that recalls the popular portable turntables from the past. Vinyl Transport has a rugged case with a handle so you can carry it anywhere. It plays all your 33 1/3, 45 and 78 RPM records, it comes with a 45 RPM adapter, and it has built-in stereo speakers for convenient listening without having to connect external speakers. In addition, it has RCA outputs for simple connection to home audio equipment and a convenient Auto-Stop feature kicks in when it reaches the end of the record.
- ION Audio Vinyl Transport - turntable
- Product Type
- Turntable
- Audio Channels
- Stereo
- Turntable
- Semi-automatic 78 rpm, 33.3 rpm, 45 rpm
- Speakers
- 2 x main channel speaker - built-in
- 34.9 cm x 25.4 cm x 11.4 cm
- 2.8 kg
- Product Type
- Turntable
Audio System
- Audio Channels
- Stereo
- Functions
- Turntable
Speaker System
- Speakers
Turntable
- Semi-automatic
- Speeds Supported
- 78 rpm, 33.3 rpm, 45 rpm
- Connectors
- Audio line-out (RCA x 2) - rear
- Included Accessories
- Power adapter, 45rpm vinyl adapter
- 34.9 cm
- 25.4 cm
- 11.4 cm
- 2.8 kg
