Product
ION Audio Vinyl Transport Portable Suitcase Turntable
Quicklinx: BV39WS00 Mfr#: VINYLTRANSPORT
Vinyl Transport is a classically-styled suitcase turntable that recalls the popular portable turntables from the past. Vinyl Transport has a rugged case with a handle so you can carry it anywhere. It plays all your 33 1/3, 45 and 78 RPM records, it comes with a 45 RPM adapter, and it has built-in stereo speakers for convenient listening without having to connect external speakers. In addition, it has RCA outputs for simple connection to home audio equipment and a convenient Auto-Stop feature kicks in when it reaches the end of the record.
ION Vinyl Transport - turntable
Turntable
Audio Channels
Stereo
Turntable
Semi-automatic 78rpm, 33.3rpm, 45rpm
Speakers
2 x main channel speaker - built-in
34.9 cm x 25.4 cm x 11.4 cm
2.8 kg
Turntable
Audio System
Audio Channels
Stereo
Functions
Turntable
Speaker System
Speakers
Turntable
Semi-automatic
Speeds Supported
Connectors
Audio line-out (RCA x 2) - rear
Power adapter, 45rpm vinyl adapter
34.9 cm
25.4 cm
11.4 cm
2.8 kg
