Product
ION Audio Vinyl Motion Deluxe Portable Suitcase Turntable
Quicklinx: BV3BWS00 Mfr#: VINYLMOTIONDX
£69.10 ex VAT
£82.92 inc VAT
We all fondly remember those classic suitcase turntables of yesteryear: easily portable, easy to use, and a party wherever you were. Here it is again, but updated with all the modern performance enhancements that only ION can bring you. Vinyl Motion Deluxe has a rugged case with a handle so you can carry it anywhere. It plays all your 33 1/3, 45 and 78 RPM records, it comes with a 45 RPM adapter, and it has built-in stereo speakers for convenient listening without having to connect external speakers.
But while Vinyl Motion Deluxe delights the eye with its beautiful 1950’s style, it excites the techie with its cutting-edge performance features: It converts any LP to a digital file, using the included ION EZ Vinyl/Tape Converter software and USB connection cable. Most amazing of all, it has a built-in rechargeable battery so you can enjoy Vinyl Motion Deluxe whether you’re near a wall plug or not.
ION Vinyll Motion
Turntable
33.3rpm, 45rpm
Turntable
Speeds Supported
33.3rpm, 45rpm
Brand: ION Audio
Price Range Ex VAT: 50 - 100
