Block Rocker Bluetooth is an all-in-one wireless sound system for smartphones, tablets, microphones, and instruments. Designed to deliver powerful sound anywhere, Block Rocker Bluetooth comes equipped with a 50-Watt speaker that projects your music, loud and clear. Its wireless capability means you can keep your smartphone or tablet right by your side as you play your music from up to 100 feet away. Plus, the Easy Pair feature connects NFC-enabled smartphones with just a simple tap. Block Rocker Bluetooth provides up to 50 hours of on-the-go sound with its long-lasting rechargeable battery. A powerbank with a fast-charging USB port and the device cradle ensure your tablet or smartphone stays powered up and sits securely. For maximum portability and easy setup, Block Rocker Bluetooth features rugged wheels and a telescoping handle.
- ION Audio Block Rocker Bluetooth M5 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- AM/FM radio
- Speaker Type
- 2-way - active
- Peak Power
- 50 Watt
- Frequency Response
- 77 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - mono - 50 Watt - 77 - 20000 Hz - 2-way - active
- Black
- Power
- AC 120/230 V (50/60 Hz)
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lead Acid
- Product Type
- AM/FM radio
- Enclosure Colour
- Black
- Design Features
- Phone/tablet stand design
Speaker System
- Speaker Type
- 2-way - active
- Peak Power
- 50 Watt
- 77 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth 4.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Controls
- Microphone volume, power on/off, volume, activate Bluetooth
Speaker System Details
- Speaker Details
- Speaker - mono - 50 Watt - 77 - 20000 Hz CFR - 2-way - active
- Driver Details
- Speaker: woofer driver , Speaker: tweeter driver
- Connector Type
- 2 x DC power output (4 pin USB Type A (power only)) , Microphone/guitar audio input (phone mono 6.3 mm) , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, microphone, power cable
- Power Source
- Battery
- Voltage Required
- Options
- USB charging
- Rechargeable - Lead Acid
- Run Time (Up To)
- 50 hour(s)
