Your basket is empty
IO Gear 4-Port USB Cable KVM Switch
Quicklinx: B6CJWS00 Mfr#: GCS24U
IOGEAR's GCS24U 4-Port USB Cable KVM allows users to share a VGA monitor, a USB mouse, and a USB keyboard between four computers. Users can switch between computers using a manual switch located on a wired remote control that can be placed conveniently on your desk. It offers an out-of-box / entirely plug-in-play solution with no additional cables or software installation needed. It supports multiple operating systems. It is also powered through the USB bus and thus does not require a power supply to run. It is the ideal KVM for those who want a competitively priced, entry level KVM that will allow them to multitask with four computers at their disposal.
IOGEAR USB Cable KVM Switch GCS24U - KVM switch - 4 ports
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user
16.2 cm x 6 cm x 20 cm
0.67 kg
UNIX, Linux, Apple MacOS 9, Apple MacOS X 10.x, Oracle Solaris, Microsoft Windows 7 / 8.1 / 10
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
4 x VGA HD-15 , 4 x keyboard (USB) / mouse (USB) Type A , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
4 x keyboard / mouse / video cable - 1.2 m , 1 x remote control cable - 1.8 m
DDC-2B, RoHS
16.2 cm
6 cm
20 cm
0.67 kg
Limited warranty - 3 years
50 °C
0 - 80%
